Adjusting height on Megan EZ Street Coilovers
Old 10-28-14, 02:56 PM
getafewliv
getafewliv's Avatar
Default Adjusting height on Megan EZ Street Coilovers
Does anyone know the limit on how far you can adjust Megan EZ Street coilovers? Not going lower... but the upper height limit?
I am currently quite low up front and when I put on my snow tires, I want to raise the car up. When looking at the hole on the shock body, I can already see the threads. Does anyone know how far past that I can safely adjust them?
Old 10-29-14, 01:30 PM
jay90011
jay90011's Avatar
The upper limit should be the exact same height/length as stock height.
Old 10-29-14, 04:53 PM
getafewliv
getafewliv's Avatar
Do you know what that would look like if I am just adjusting the coilover while it is on the car?
It doesn't look like there is any sort of physical stop mechanism, and I am worried that if I keep raising it, I will run out of enough threads to properly support the weight. I am fairly certain the bottom of the black threads inside the silver cylinder are right at the little view hole, and I have maybe a half finger gap above my tire.
Old 10-30-14, 04:09 PM
FSportIS
FSportIS's Avatar
Sorry to ask but why would you raise it to stock like height when you run a coil set up?? Don't you want to lower it?
I think you can raise it all the way up to 3 fingers gap like the stock like height without problem.
Old 10-31-14, 10:20 AM
getafewliv
getafewliv's Avatar
Not to stock height, but right now my front is lower than where it was with H&R springs and I would like it about the same to avoid scraping my bumper in parking lots. Also, for winter I would like a little more ground clearance.
But based on the current height of my car and where the threads are, it seemed like there's no way I could go to a 3 finger gap.
Old 10-31-14, 10:57 AM
FSportIS
FSportIS's Avatar
I have the same concern like you do lol. That is why I still stayed with lower springs. I think you can have 1-2 finger gap in front like you have on your H&R. That is definitely doable. The default setting on coil is at least 1 inch lower i think. The thing about coil is that the shock is shorter than the normal shocks to compensate for less travel for the suspension.
Old 10-31-14, 01:59 PM
getafewliv
getafewliv's Avatar
It just seems weird that there's no stopper or way to physically stop from raising the coil past its limits. I don't know if that little view window is meant to be the limit, or if you can go beyond that point...
Old 10-31-14, 02:50 PM
FSportIS
FSportIS's Avatar
I think it is best to consult with Megan, or your mechanic as they know best. I think it is safe to have 2 fingers gap or so.
This is the link to contact them. http://www.meganracing.com/contact/contactus.asp
cheesey1x
26
05-01-13 11:19 AM
AltezzaIS3
Suspension and Brakes
12
10-26-12 11:18 PM
xtremex626
85
05-23-12 03:33 PM
96732IS350
08-05-11 05:55 AM
Krupted760
03-24-11 04:33 PM
Quick Reply: Adjusting height on Megan EZ Street Coilovers
