How to remove RF axle on an AWD?
Hey guys looking for advice on removing the rf axle on my 08 is250!!!
It seems like the bearing is siezed in the housing pretty good,
ive been whacking it with a 12lb hammer for a while and its not budging.
Any advice from ppl who have done this succesfully would be great!
I cant remove it from the tranny side where the bearing is pressed over the shaft and inside the housing of the engine side.
those carrier bearing support brackets are notorious for being seized. (any make or model) if you are looking to replace the axle shaft, you'll need to buy a new bearing support bracket. if you are just removing the axle to do something else, you'll need to pull the bracket down with the axle
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/new_axle_21495db759f27930c9612297a7e0c1038bb138b2.jpg)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/old_axle_02de9c8169f42f1cdb4a739954ab7136cfd6977d.jpg)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/wheel_well_view_3afcb5d5eae679e941089044fc2c0bf3188311a3.jpg)
Heres what im up against. I really dont see any way of getting this bearing loosened up without heat.. But im worried if I heat it too much ill burn up the seal thats behind it and whatever else is inside...
not to mention i dont have the means to heat more than a propane torch.
Yes i have removed the c clip from the bearing housing. Ive pounded the axle cup from underneath with a sledge hammer, Also used a sliding hammer attached to the cup and still doesnt budge.
I had a half shaft get stuck in a Quaife LSD equipped trans I built and I ended up punching it out of the trans housing from the opposite side. No diff pin to get in the way luckily. Would that even be possible in this case?
Not familiar enough with the 2IS AWD model setup; just trying to throw out ideas here.
That's actually a picture of the drivers side I'm guessing... The first picture you posted was in fact the passenger side. It is about a ft longer past the bearing which extends into the transaxle. And yes as I mentioned before I can get to it from underneath with a sledge hammer, can't get to it with a pry bar though.
Did anyone ever figure out how to remove the axle? I have the same problem. The bearing is seized in the engine housing. Any follow-ups would be appreciated.
