Rear upper control arm bushings
Hey, I have a question. Iam having a tire wear problem in the rear passenger side of my gs300. Checked the bushings and noticed the the upper control arm bushings are cracking. Can I just replace the bushings or do I have to replace the whole arm?
You can do the bushings. They are a complete PAIN. you have to drop the subframe to get to them. If your going to do it get these.
http://shopfigs.com/v1/index.php?rou...product_id=110
Do you have to drop the subframe to get the control arm out? Is it not possible to get a socket wrench in there to remove the bolts? And has anybody removed the ball joint with a pitman arm puller? Or is the pickle fork really the only way?
I am working on my sc430, same rear setup. I was able to get the rear out. The rear nut was very hard to get to, and I have no idea how I am going to get the washer and nut back on, but it is in my hand now.
I have the loose bushings in hand, and trying to figure out how best to press them in. I have never pressed into aluminum. Thinking the freeze the busing, heat the aluminum arm trick.
Suggestions appreciated.
Ball joint press, bushing driver set and deep impact socket. Also a torch to heat the arms.
Step 1: remove arm
Step 2: clamp in vise
Step 3: Set the press and correct driver over the bushing.
Step 4: heat arm till bushing starts smoking
Step 5: tighten clamp and hope for it to start moving.
Step 6: if you run out of press length add a deep impact socket.
If you have never done a ball joint or bushing replacement, I would strongly recommend having a shop press out the bushings for you. As to replace the are is close to $700
Step 1: remove arm
I finished replacing the rear upper control arms with FIGS poly bushings today. Overall it wasn't too bad of a job, initially trying to loosen the bolts was hard but it just took patience. Reaching up and around to hold and mess with the washer and nut wasn't too bad either for me. I had a shop press out my old bushings.
Step 1: remove arm
Step 1: remove arm
but if they are aluminum, i wouldnt heat them up. just press them out.
I had a shop press them out. I don't think they heated them up, there's some gouges around the side probably because they had to use an air chisel to lift the lip on one side in order to press them out.
realsync1
12-14-22 11:00 AM
Swedish
10-04-18 04:35 AM
