Rough noisy ride on Megan EZ Street Coilovers
Regarding preload, this video shows you exactly step by step how to set it properly. They use BCR coilovers as an example though.
BC Racing Coilover Spring Change and Preload Adjustment on Vimeo.mp4 - YouTube
Finally got around to dealing with this. I adjusted the preload on the back 2 coilovers a few mm. They seem to be a lot better now! On really big bumps, I feel like there's a little bit of noise, but that could be normal.
I can finally set them to a much softer setting and they ride quiet and nice
Glad it was a fairly easy fix and didn't require removal or replacement.
Yeah, see, don't judge the book by its cover so don't judge the coil by its noise
Sometimes it is not the coils being bad. It is the pre-load, the dampening settings that you choose that makes you feel like it is bad lol. May be you should rephrase the title to make it more fair for Megan
Sometimes it is not the coils being bad. It is the pre-load, the dampening settings that you choose that makes you feel like it is bad lol. May be you should rephrase the title to make it more fair for Megan ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Haha I feel like every mod I have done to the car has had to be done at least twice to get it proper. But oh well, once everything is working smoothly, it's all worth it.
This is also the root of my issues since they were fiddling around with the coilovers. I know they screwed the bottom part on way too far which lead to my car being way too low when I first put them in.
