L-Tuned Alternatives? Sounded like the perfect setup for me, but discontinued...
Old 01-22-15, 02:23 PM
Ahheck01
Ahheck01's Avatar
Question L-Tuned Alternatives? Sounded like the perfect setup for me, but discontinued...
Considering front and rear RCAs cost nearly as much as a decent set of shocks/springs, I've been looking into various combos out there.
From the reviews, it sounds like the L-Tuned setup was exactly what I want - Minor drop, less roll, more confidence-inspiring handling, without much of a comfort sacrifice. "The way it should have been from the factory."
It seems nearly impossible to get a set that's not worn out, so I'm curious what the closest alternative would be?
I see a lot of reviews of the Bilstein HD's with stock springs being a comfortable but more controlled setup than stock, and could use RCAs for a drop if needed, but that'll add up to more.
Thoughts?
Old 01-22-15, 05:14 PM
angus
angus's Avatar
I suppose Tein S-tech would be close.
Old 01-22-15, 09:11 PM
Ahheck01
Ahheck01's Avatar
Why do you say that? In what respects? Ride height? Spring rate? What shocks would need to be paired with them for similar results?
Old 01-24-15, 10:23 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Tanabe DF or NF springs... DF is lower than NF...
Old 01-24-15, 06:48 PM
angus
angus's Avatar
TMF is actually correct, the NF are the softest.
I'd actually consider Bilstein shocks (HD) NF springs and RCA's for my daily
Old 01-24-15, 06:51 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,273 Likes on 1,380 Posts
I recall L-Tuned springs were made by Eibach and the L-tuned shocks were rebadged KYB. You might be able to find both of them new somewhere still; worth looking.
Old 01-24-15, 06:53 PM
tmf2004
tmf2004's Avatar
that would be great daily ride.... not to low but tight around turns...
Old 01-24-15, 06:54 PM
angus
angus's Avatar
I'd say it could be fairly low if you did 40mm F. and 30mm R. RCA
Old 01-24-15, 07:00 PM
tmf2004
tmf2004's Avatar
OP, you can go to this thread and look at various setups with S/S and coilovers...
https://www.clublexus.com/forums/sus...d-threads.html
Old 01-24-15, 07:01 PM
Ahheck01
Ahheck01's Avatar
Honestly I don't want it to be that low, just reduce front wheel gap a little. I figured 40mm front and 30mm rear would be about perfect. I think a drop from spring or rcas would do it. A combo would probably be too low for me.
Old 01-24-15, 08:06 PM
tmf2004
tmf2004's Avatar
i think the DF would be good then... it would the gap more then the NF's.. look through that thread i posted... many members used those springs and you can get an idea of the gap
Old 01-25-15, 11:14 AM
Ahheck01
Ahheck01's Avatar
The NF seem to have the ideal balance for me. Just curious what shocks I should pair with them that are best match with their spring rate and suspension travel.
Old 01-25-15, 05:53 PM
angus
angus's Avatar
If you are looking to simply lower it with no other changes to the "feel" then RCAs are DEFINITELY the way to go.
If you want to further improve handling then get the TRD sways.
Anytime you reduce travel by installing shorter springs, your ride will get worse to some extent.
Old 01-25-15, 05:57 PM
angus
angus's Avatar
Believe me, I am considering going back to stock springs with Bilstein HD shocks in my DD.
I recenttly drove my uncle's stock 2GS and I can tell you that it sure was nice...
While I love the handling - in my old age I feel like the plush, long travel suspension might suit me better sometimes - mannnnnnnn I'm soooo OLD!
I kind of want to see how much the handling suffers if I go from the current Bilstein PSS to stock springs with HD Bilsteins, I'd keep my RCA and TRD sways.
kwamdoo74
Suspension and Brakes
05-06-08 08:49 PM
suprandsc
04-19-07 09:47 AM
chrisleX
03-11-04 03:58 PM
Hameed
01-27-03 10:17 PM
shadow
01-24-03 04:08 AM
Quick Reply: L-Tuned Alternatives? Sounded like the perfect setup for me, but discontinued...
