New Coilovers, Questions On Instilation.
Well, not so much as how to install them, I know how, more along the lines of how to install them without risking any damage to the ABS Wheel Speed Sensor, Ive read that its very common when people do brake or suspension work on these cars they tug, snag or break the ABS WSS wires, whats the best way to insure no damage to the wires, any tricks anyone has used like tying them back. Any bit helps. Thanks!
If you're only swapping shocks you can do it without much chance of damage, just unbolt them from the inner fender for more slack and be careful.
If you decide to undo the upper BJ - then you can use a heavy bungee cord to prevent the knuckle from coming out and pulling the wire.
