NEED HELP BEFORE TOMORROW! Brakes/Rotors
Old 01-29-15, 12:52 PM
oldManTan
oldManTan's Avatar
oreillys resurfaced my TT rotors for 30 bucks. i'll sell em to you if you want, can get started on your TT brake setup. advance auto sells TT front calipers for 100 a piece, if you can find them in stock.
Old 01-29-15, 10:16 PM
Dougspeed
Dougspeed's Avatar
When you say that you have "racing rotors", what do you mean exactly? Are they drilled, slotted, or drilled and slotted? If so, no shop will turn those. Once they're done, they have to be replaced. Also, does your car vibrate when you hit the brakes at all? If not, it's unlikely you need to have the rotors replaced. Just change the pads for now until you decide if you want to upgrade them to TT or LS400 calipers along with wheels that clear those.
Old 01-30-15, 12:45 AM
SC400Zulu
SC400Zulu's Avatar
Originally Posted by t2d2
I had that same experience years ago when I paid a large sum of money to have a new battery installed. I was looking back for the receipt (it died like one month out of warranty...) and couldn't believe how much I wasted on something I knew by then to be one of the easiest things you can do on a car.
LIkewise, brake work is fairly intimidating if you don't know the steps, being a fairly mysterious looking contraption and vital safety equipment. I've watched my mechanic a few times now while doing struts and wheel studs, and finally feel like I'm familiar enough to change pads myself without giving it a second thought.
They're +50, same as stock SC wheels. They only have a sliver of clearance over stock SC calipers in front. It would require a thick spacer to clear LS calipers, and possibly a fender pull.
Yeah, I'd need new wheels. A 25mm spacer at my height, would rub on tight turns.
I wish I had a garage to tinker around in. I heard the secretary mention to someone they could turn the rotors. I will ask if it can be done. They had the car in a lift when checking.
Also, I don't have vibration while braking. Don't think the rotors are uneven.
Old 01-30-15, 12:47 AM
SC400Zulu
SC400Zulu's Avatar
That be great! I will check now. I can't run TT calipers on non supra rotors?
Read my signature. The rotors are Brembo, cross drilled. Not slotted though. And you're right. Night just tell them NVM and get the pads done only.
Old 01-30-15, 02:06 AM
SC400Zulu
SC400Zulu's Avatar
I think my problems are solved. Thoughts?
Old 01-30-15, 09:00 AM
Dougspeed
Dougspeed's Avatar
No need to change the rotors if there is no vibration. Deals like you posted above are always popping up but you don't need it right now. Just change the pads and you're good to go.
Old 01-30-15, 03:31 PM
oldManTan
oldManTan's Avatar
i'd go with OEM pads, from reading reviews it seems that the EBC pads take a bit to warm up and start grabbing.
Old 01-30-15, 05:42 PM
SC400Zulu
SC400Zulu's Avatar
Thanks guys. No vibration. Just a little squeak upon hard braking due to worn pads
Old 01-30-15, 09:53 PM
SC400Zulu
SC400Zulu's Avatar
Just ordered these with express shipping.
Old 02-02-15, 12:43 PM
Ali SC3
Ali SC3's Avatar
I didn't read the sig, if you have brmebo rotors just leave them be and tell them to change the pads.
eventually when you brake at high speeds you will feel that vibration that tells you the rotors are warped, and with brembo rotors that may be several pad changes cause they are good quality. I would not change them out until it gives issues, just do the pads. good luck!
jham808
RX - 3rd Gen (2010-2015)
08-10-15 10:31 AM
SpmMorrow
IS F (2008-2014)
08-28-12 05:44 AM
truenoboy
Suspension and Brakes
05-19-09 06:27 AM
syn1313
04-24-09 12:32 PM
OneGuyInCA
RX - 1st Gen (1999-2003)
03-14-08 10:11 PM
Quick Reply: NEED HELP BEFORE TOMORROW! Brakes/Rotors
