Question for those running 19's
I'm considering moving up to some Work 19 inch wheels, but I DD this car about 15-18k a year. I'm pretty nervous about dropping to a 30 series tire in the rear. I haven't done the math on what the sidewall height difference would be if I go to a 265 in the rear or other options. Basically, I'm wondering if anyone running 19 inch wheels could tell a big difference going from stock to 19? Roads aren't too bad in NC, but I don't want to regret this if I'm gonna spend 2-3k in wheels and tires.
You will lose 0.3" sidewall on the front with 235/35/19 and 0.4" on the back with 265/30/19
The change is not that dramatic because although you are increasing wheel size, overall tire diameter increases slightly as well. The type of tire you pick may have to do a lot with the ride comfort...
I went from 235-50-18 Pirelli P Zero Nero tires on my Mustang to 255-40-19 Michelin Pilot Super Sports (square setup). Ride quality improved and handling improved exponentially. The tire you choose may compensate for the loss of sidewall height going to 19" wheels/tires. I can't speak highly enough of the Super Sports.
