Brake Master Cylinder - Pressure Sensor code after BMC swap
Old 02-08-15, 10:02 AM
kit cat
kit cat's Avatar
Default Brake Master Cylinder - Pressure Sensor code after BMC swap
BACKGROUND
Car: 98 GS400, 250k+ miles
Brake Mods:
01-05 brake master cylinder (BMC).
Taken off a rear ended 2003 Sport Design with about 70k miles.
Installed by a well respected shop and yes, BMC was bled properly.
Front: Supra turbo calipers, OEM pads, OEM rotors
Rear: Stock caliper, Akebono Premium pads, OEM rotor
Stainless steel lines to all 4 channels, ATE blue
SYMPTOM
After the new BMC, the VSC/ABS/ABS OFF light is still on.
Code is for the BMC pressure sensor and rear passenger side vehicle speed sensor (VSS). Rear passenger VSS was replaced but code for rear passenger VSS still comes on also.
I can clear the code but after driving a minute, light and same code comes back on...
QUESTION
Has anyone experienced this pressure sensor code after swapping the BMC or can think of where I should start to trouble shoot? Before I start using a multimeter and check if the prongs/sensors, if anyone has experienced this and resolved, please do share.
I'm not too worried about the rear passenger VSS at the moment. This light is driving me nuts...
thanks in advance!
Old 02-08-15, 06:57 PM
Dube
Dube's Avatar
Originally Posted by Coco-bun
BACKGROUND
Brake Mods:
SYMPTOM
QUESTION
thanks in advance!
replace the sensor with your old sensor.
Old 02-08-15, 09:55 PM
kit cat
kit cat's Avatar
You just beat me to it...
I talked to a friend a few hours ago and he brought up the sensor too. I didn't know about it and didn't tell the shop to swap the sensor; this is my fault
(embarrassed, runs away)
V8Life
05-20-19 11:09 AM
Fritz330
07-03-16 07:45 PM
Nexgen76
ES - 5th Gen (2007-2012)
11-05-15 02:35 PM
RayN
RX - 1st Gen (1999-2003)
01-17-15 09:23 AM
Lexs400
Maintenance
09-12-09 01:25 PM
Quick Reply: Brake Master Cylinder - Pressure Sensor code after BMC swap
