Help with Alignment Results? Any Concerns after slight drop?
Hey gents (and ladies), just got back from Firestone after installing the following:
Tanabe NF210 springs
Figs Front Lower Control Arm Bushings
Figs Caster Arm Bushings
Moog Tie Rod Ends
Moog Inner Tie Rods
Moog Ball Joints
Here's the printout:
They're hitting the limit of adjustment in a few cases - curious what you all make of this? I'm going to put new wheels/tires on next week, so going to take it back in since I got the lifetime alignment. What should I ask for? Any other advice?
Cheers!
Moog Tie Rod Ends
Moog Inner Tie Rods
Moog Ball Joints
Cheers!
Your alignment is fine
Camber is fairly even and the caster is ever so slightly out of spec, but not way off.
The Firestone around here does horrible alignments and work in general so I'd never go to them, but your alignment is not necessarily bad.
yeah looks fine to me too.
my drivers rear wont get into spec for the toe though . ".28" as it sits now. irratates me.
but i figs adjustable caster bushings. mine sit almost at 8 on both sides. feels good
