is-f rotors on is300
I'm not sure how big the IS-F rotors are but I do know that Figs sells a bracket that'll let you run the 323mm Supra rotors with the stock IS300 calipers
You're going to need a custom bracket regardless but I'm not sure why you'd want to run just the IS-F rotors
because this car will be track only with hopefully 550 whp and i want to have plenty of brakes, i learned it hard way on my sti and it has 325whp only
my sti is still DD too but lexus im building track only so i want to go all the way
unless there are cheaper/different options
is-f rotor is huge that is why i was thinking about it
Personally im going with the supra tt conversion. With the supra tt conversion i know you will need atleast a 15mm spacer and this kit and then you can order up the stock oem parts from the supra tt.
http://shopfigs.com/v1/index.php?rou...&product_id=60
