2011 IS 350 AWD with F Sport Springs
For those of you that have the F Sport springs on your 350 AWD, did you get the rubber silencer to go with it??
My friend is going to install this soon and before doing so, we just want to make sure that the rubber silencers aren't needed for this model.
The rubber silencers were going to be from TEIN, since they're a lot cheaper than getting them at the dealer and the specs are 90-130mm.
IF it matters, it will be F Sport springs on the OEM shocks.
Thanks in advance!
Thanks in advance!
I have F Sport springs installed on my 250 AWD and they were installed without silencers on them paired with F Sport shocks. It's been a few months and a few thousand miles since then but it's rather quiet. The only noise complaint I really read about was when it was paired to the F Sport shocks because the spring perch is not welded to the shock body but a piece that you have to place onto during installation. Hope that gives a bit of insight for your case.
