IS250 RWD brake upgrade to IS350
Has anyone done a brake upgrade from the IS250 to the IS350?
2013 and below has an option you can purchase, but not the 2014+
http://is.sewellparts.com/accessorie...2013/2045.html
They will work but I might suggest rock auto where you can get loaded IS350 calipers for $500 per pair or you can get a pair of calipers without pads for $260 per pair and get a good set of stoptech pads for $50. Boom, full brake upgrade for under $350.
Mike
Mike
Yes the sizes are the same because they are actual IS350 calipers. They are just remanufactured. They should come with a warranty. If and when the seals finally wear out you can just replace them for about 10 bucks in parts. Normal caliper maintenance.
Mike
Mike
Well that totally depends. Are you running out of brake because of overheating during tracking or canyon runs? Are you overheating your pads and/or fluid? If yes, these will prevent that. If no, these will do nothing for you.
Mike
Mike
Thanks for the into. Im not tracking the car, nor doing canyon runs. I just love the look of the bigger breaks and rotors.
But I do beat on her and play in the turns when I can.
