PERFORMANCE coilover question
Need a new suspension, 120k miles on my IS350 and im feeling pretty soft I did plenty of searches on the forums for coilovers and so far everyone just talks about what the best suspension is for lowering their car. I'm not looking to drop my car more than an inch. I just want performance/stiffness.
QUESTION: I need to know if Megan EZs will give me a hefty handling/body roll improvement over stock suspension.... or if I need to go with BCRs for that. kinda on a tight budget. Thanks guys
Fire Slayer
Although most people don't talk about the stiffness or performance aspect of coils, they are. Megan EZ's will be stiffer and lower at the same time although BCR's will have stiffer spring rates and even customizable spring rates that are stiffer than theirs normal set up. Do you plan on auto crossing the car?
Very spirited driving will definitely be going down. I would say its pretty similar to auto x
Already have the rear sway, may go for thr front as well tho. Thanks appreciate the help!
You should get the front sway bar! i did recently and big improvement in neutralizing the steering and less front body roll in front. also, Megan EZ should be fine but softer than BCR. you should also invest money in TIRES because that improve handling A LOT.
Oh, i do autocross and track a lot too, glad to see you doing the same.
I will probably be getting the front sway then. I just remember people saying the front and rear sway bars make ur car lose traction easier which doesnt make too much sense to me. Dont worry I have good summer and winter tires. I dont play around when it comes to that. I'm running wider than stock too.
Now the softer part isnt an issue correct? My experience so far is softer = less handling. I want a vast improvement over stock. Thanks!
