Cusco Sway bars.. upgrade bushings/endlinks?
Old 03-09-15, 09:11 AM
MrHarris
MrHarris's Avatar
Default Cusco Sway bars.. upgrade bushings/endlinks?
I have Cusco front/rear sway bars with stock sway bar bushings and end links.
Should I upgrade them to FIGS? Will I feel any noticeable difference?
Old 03-09-15, 12:24 PM
Gville350
Gville350's Avatar
Doubtful; F-sport/Cusco/Hotchkis all use upgraded polyurethane bushings. Best save the money for another one of their many bushings.
Old 03-10-15, 04:45 AM
MrHarris
MrHarris's Avatar
Sadly the guy who installed it said he used the OEM bushings... that have 130k miles on them....
Old 03-10-15, 08:36 AM
scott1256c
scott1256c's Avatar
The oem bushings are going to have more give to them than poly bushings. Unless they are worn, I doubt you would see too much difference. I say that thinking about how the bar will move in a turn, not because I tried it both ways. I guess the guy who installed them threw out the bushings? You can check with figs, but you will have to make sure the bushing matches the thickness of the bar. Your best bet might be to contact cusco.
Old 03-10-15, 12:26 PM
Gville350
Gville350's Avatar
But the sway bar comes with new bushings. Did you get a used bar or something? Or did the shop just toss your brand new ones?
I would replace the worn, OE ones.
Old 03-10-15, 01:48 PM
MrHarris
MrHarris's Avatar
That fool tossed the new ones cuz another shop said I have the OE bushings on there... and I bought the Cusco's brand new.
Old 03-10-15, 01:55 PM
MrHarris
MrHarris's Avatar
Guys, what about FIGS Front and Rear sway bar end links? They are like $150-170 each but are they worth it? I saw the stock end links and they are dinky as ****.
Old 03-10-15, 03:55 PM
scott1256c
scott1256c's Avatar
I haven't put that many miles on the car since I added the front sway bar. The front uses the stock links. They haven't bent yet . The rear (Sikky) came with adjustable links, so I am using those. They seem like pretty good quality. I'm not in a position to speak about the figs end links. If you are lowering the hell out of your car, you may need adjustable end links to get a good 90 degree angle between the link and the bar. I have no idea how much play is in the bushing on the stock link, but I don't hear people complaining about the stock ones failing or anything.
Old 03-10-15, 04:06 PM
MrHarris
MrHarris's Avatar
I'm going to get the bushings and end links for front and rear from FIGS since my cusco sways I think can do a little bit better in body roll reduction considering my setup.
Anyone know any common bushings that wear out that I should replace that FIGS make?
Old 03-11-15, 01:04 PM
Gville350
Gville350's Avatar
The front lower LCA bushings AND the rear diff bushings are what I have found have worn incredibly quickly. I've got myself the replacement LCA bushings and have yet to pull the trigger on the rear diff bushings. I just might wait until the LSD comes into play later this year to do the diff bushings.
Old 03-20-15, 08:36 PM
MrHarris
MrHarris's Avatar
DId you notice any performance/handling difference when you replaced your OEM bushings with FIGS?
What sway bars do you have?
Old 03-21-15, 07:48 AM
Gville350
Gville350's Avatar
^The bushings are sitting on my workbench. I need to go out today and purchase whatever I'll need to do the bushing removal/install myself.
I've just got an F-sport rear bar and stock front sway. I find it suits my driving style better being more "loose" upfront.
Old 03-22-15, 02:03 PM
MrHarris
MrHarris's Avatar
So is it a real noticeable difference replacing the OEM bushings and endlinks with FIGS bushings and endlinks? It's $400 total so it isn't cheap but I do have legit sway bars.... what you guys think?
Old 03-22-15, 02:05 PM
Gville350
Gville350's Avatar
^I doubt anyone has specifically done that exact upgrade. So you'll be hard-pressed to get the answer you're looking.
In my opinion, I'd just do the bushings, since the OEM ones will fatigue over time.
HammerDown
Suspension and Brakes
01-30-15 07:09 PM
Scott1258
12-10-07 10:25 AM
GSquicksilver
34
02-16-06 01:12 PM
Quick Reply: Cusco Sway bars.. upgrade bushings/endlinks?
