R1 Concept Premium Rotor kit
Heel & Toe
Considering getting this to replace my stock setup.
Ordered: 1 Filled: 1 105.04761 PQ Ceramic Brake Pads $62.44 Ship Date:
Ordered: 1 Filled: 1 105.05720 PQ Ceramic Brake Pads $59.95 Ship Date:
Ordered: 1 Filled: 1 PDS.44081R Right: Premier-Series Double Drilled Diamond Slotted Disc Brake Rotors $101.47 Ship Date:
Ordered: 1 Filled: 1 PDS.44081L Left: Premier-Series Double Drilled Diamond Slotted Disc Brake Rotors $101.47 Ship Date:
Ordered: 1 Filled: 1 PDS.44082R Right: Premier-Series Double Drilled Diamond Slotted Disc Brake Rotors $107.99 Ship Date:
Ordered: 1 Filled: 1 PDS.44082L Left: Premier-Series Double Drilled Diamond Slotted Disc Brake Rotors $107.99 Ship Date:
Sales Tax: $0.00
Shipping: $0.00
Discount: ($201.96)
Surcharge: $0.00
Grand Total: $339.35
Sales Tax: $0.00
Shipping: $0.00
Discount: ($201.96)
Surcharge: $0.00
Heel & Toe
Look into there other product line.......r1 concepts eline......they have combos with rotors+pads on ebay check them out....
I called R1 yesterday, since they don't have an ebay listing for the cross drilled & slotted they matched the price with their premium cross drilled kit on their ebay listing.
I read on other forums to go with the premium rather than eline. But price wise you can beat the eline.
I have the LS400 front slotted rotors and rear slotted SC300 rotors .....They are good quality
For LS400 - I will need a spacer or buy a bigger wheels & tires setup and cut the back plate
For TT - I will have to buy a bigger wheels & tires setup (17" or baove)
I might not have enough budget to go with the above.
Thank you for your input.
Heel & Toe
Currently, I have the blank rotors setup and they rust up a lot on my DD cars. After a car wash or rain, I couldn hear noises (squeaking grinding) after a few miles it goes away. Trying to go with a different setup.
I understand you are doing stock brakes...I was just referencing what I have and that the quality of rotors is fine....r1 concepts eline are fine unless you really want to get premium rotors....
Just search for eline sc300 on eBay...you can get all 4 rotors and pads for around $200
Heel & Toe
I would do slotted rotors over cross drilled...
Again, just keep feeding me the info. I am still undecided. but the eline price is really good.
Heel & Toe
eLine Series Rotor Kit
I ended up ordering the eLINE Series below.
Ordered: 1 Filled: 0 105.04761 PQ Ceramic Brake Pads $62.44 Ship Date:
Ordered: 1 Filled: 0 105.05720 PQ Ceramic Brake Pads $59.95 Ship Date:
Ordered: 1 Filled: 0 EDS.44081L Left: Performance Drilled & Slotted Disc Brake Rotor $72.99 Ship Date:
Ordered: 1 Filled: 1 EDS.44081R Right: Performance Drilled & Slotted Disc Brake Rotor $72.99 Ship Date:
Ordered: 1 Filled: 1 EDS.44082L Left: Performance Drilled & Slotted Disc Brake Rotor $61.99 Ship Date:
Ordered: 1 Filled: 1 EDS.44082R Right: Performance Drilled & Slotted Disc Brake Rotor $61.99 Ship Date:
Ordered: 1 Filled: 0 950.44008 SS Brake Line Kit $69.59 Ship Date:
Ordered: 1 Filled: 0 950.44506 SS Brake Line Kit $55.99 Ship Date:
Sales Tax: $0.00
Shipping: $0.00
Discount: ($217.01)
Surcharge: $0.00
Grand Total: $300.92
Sales Tax: $0.00
Shipping: $0.00
Discount: ($217.01)
Surcharge: $0.00
Heel & Toe
Need HELP!!!
I got the e-line series kit installed with the stoptech braided brake line. I have cleaned the pin and lube it before I installed it back. Using the 2 man process, I bled the brakes several times already until the brake pedal stopped before the midway. Once I started the car and stepped on the brakes, it goes deep to the floor. I still have the car on a jack stand since the last time I tried to put back the tires and drove it, I got the same results.
You are not bleeding them correctly you dont stop when the brake pedal gets half way down....
You stop when no more air bubbles or air is in the lines.....all that should be coming out is brake fluid....and when you have that tighten the bleeder screw and move on to the next one...
Also if you dont keep the master cylinder full of brake fluid during the process you will be sucking in air....which is what you do not want...
b2designs
Club Lexus Vendor Marketplace
275
06-23-18 04:25 AM
LexiGS4ty
Suspension and Brakes
04-02-12 07:09 PM
