Sway bar end links - change both at same time?
Old 05-12-15, 09:35 PM
kingap
kingap's Avatar
Default Sway bar end links - change both at same time?
I screwed up the front passenger end link while changing suspension.
Do I need to change out left and right front end links if I'm getting an aftermarket end link, or can I just change one? I'm concerned if it will change the handling dynamics with two different brand end links on left/right.
Any experience with Moog or Mevotech?
Old 05-13-15, 05:55 AM
daileycon
daileycon's Avatar
Great excuse to get some Figs!
http://shopfigs.com/v1/index.php?rou...product_id=206
Old 05-13-15, 06:19 AM
MikeFoxx
MikeFoxx's Avatar
^^^^^ I second that lol
Old 05-13-15, 07:48 AM
kingap
kingap's Avatar
Heh, can't afford to drop $160 on end links right now, not including shipping/customs to Toronto.
Back to original question, need they be the same left and right?
Thanks!
Old 05-13-15, 08:38 AM
MikeFoxx
MikeFoxx's Avatar
You can replace just the one and you'll be fine. It's just that you are already in there and replacing them both at the same time will be easier since you'll have to at some point anyways. I have the Figs but moog products seem to be a favorite across all models on the forum. Might as well inspect the sway bar bushings while you're there and they are cheap to replace.
Old 05-13-15, 04:24 PM
Gville350
Gville350's Avatar
End links normally come as a set anyways. Unless you go OEM, you'll probably end up just getting two as a set.
hypervish
RX - 1st Gen (1999-2003)
11-22-14 09:42 AM
ayroman
02-15-11 04:47 AM
hurricane
Suspension and Brakes
15
10-30-08 06:58 PM
Quick Reply: Sway bar end links - change both at same time?
