Is250 awd staggered wheel tires
I have a is250 awd, i put on some rays staggered setup but they have a square set of tires 245/40/18 on rught now but they rub on inner plastic in half way when i turn and thats on stock height. I will be lowereing the car and im ordering new tires, so my question can i run non staggered tires on the the staggered wheel wich are 18x8 +30 front n 18x8.5 +33 in the rear and can i run 225/40/18 all around with no problems?
Welcome to CL , you ahould check the faq section , lots of info in there
both threads should help you answer your question
https://www.clublexus.com/forums/is-...-part-uno.html
https://www.clublexus.com/forums/is-...er-thread.html
Hybrid-JD
04-13-11 05:04 PM
