Supra tt caliper help
Old 05-23-15, 04:08 PM
SpectraBlu
SpectraBlu's Avatar
Default Supra tt caliper help
So I'm in the middle of installing my supra tt calipers and ran into a little problem. When I bought all the stuff for the upgrade I didn't buy stainless lines cause I thought they were already on the car, unfortunately they are only on the rear and not the front. I went to attach the gs's oem brake line and the little hook thing that's attached to the line that looks like maybe it's an anchor or something doesn't line up with the hole in the caliper, I didn't see a hole in it so I don't think it has fluid running through it. Anyways, I just moved the hook to the side and bolted the brake line in. My question is do I need to have the hook in the hole or am I ok the way I did it? Any help would be greatly appreciated, especially since my cars on jack stands right now and I can't go anywhere. Thanks
Old 05-24-15, 02:28 PM
marshun
marshun's Avatar
the hook just kept it in that position. youre fine
Old 05-24-15, 09:01 PM
SpectraBlu
SpectraBlu's Avatar
cool, thanks man. That's what I thought, just wanted to make sure
Old 05-25-15, 12:13 AM
angus
angus's Avatar
Yup done it many times, just make sure you hold the line, I used an appropriate sized wrench to stop it from turning.
Old 05-25-15, 02:01 PM
SpectraBlu
SpectraBlu's Avatar
I love this forum, everyone's always super cool and helpful. Thanks again guys
Old 06-02-15, 08:47 AM
Michelex
Michelex's Avatar
Hello .... Just install the supra tt caliper and run into the same thing, but everything seem fine the way the brake lines is hook thing is not in place......
Can anyone verify that 3gs wheels will clear on 2gs with supra TT calipers ? with out any spacer... I'm cursing have on NISSAn 350z 18" with 30mm offset and the car drive like ****......
Old 06-02-15, 11:34 PM
SpectraBlu
SpectraBlu's Avatar
I'm pretty sure the 3GS wheels will work, but not 100% sure. Hopefully someone else will chime in and help u out.
Old 06-03-15, 03:26 PM
NorthStyle
NorthStyle's Avatar
The 3GS wheels will clear the TT calipers by a few mm...
Old 06-08-15, 07:07 AM
Michelex
Michelex's Avatar
thanks you guy very much .......
Jonathan o
Suspension and Brakes
06-12-08 05:40 PM
2JZ147
GS - 1st Gen (1993-1997)
12-31-07 05:13 AM
Benjamin T
08-15-07 12:11 PM
shaitaan
11-21-06 06:16 PM
Jonathan o
08-16-06 12:24 AM
Quick Reply: Supra tt caliper help
