Sway Bar Diameter Question
Old 03-29-03, 06:50 PM
gs400998
gs400998's Avatar
Default Sway Bar Diameter Question
Could someone tell me the diameter of front and rear sway bars for TRD and Intrax/RMM? Are there any other brands for GS400? Thanks in advance.
Old 03-29-03, 11:00 PM
GS4Will
GS4Will's Avatar
i would highly recommend stay with TRD
Old 03-30-03, 08:10 AM
Received 2,486 Likes on 1,633 Posts
The TRD and stock sways are the same OUTER diameter, but the TRD ones use much thicker heavier tubing so I guess the INNER diameter is smaller. I've never seen the Intrax ones.
Old 03-30-03, 09:45 AM
skier1
skier1's Avatar
I bought the blue TRD sways (F & R) from Carson Toyota. The stock front sway bar was hollow, the new front TRD is SOLID. Both have the same outside diameter. I reused the same metal clamp that was on the car to hold up the bar. The rear bar is also the same diameter. The stock rear bar is solid and the new rear TRD is hollow! Go figure! I highly reccommend this MOD. That coupled with lowering springs and performance shocks really makes a difference from the stock ride. You get a bit more road noise and bumps, but the enhanced performance far outweighs this.
Old 03-30-03, 02:42 PM
rominl
exclusive matchup
rominl's Avatar
personally i'd most likely stay with just trd or daizen
Old 03-30-03, 07:24 PM
MrSypher
MrSypher's Avatar
Yeah stay with TRD... I got the special TRD race red ones.....
JeffTsai
Suspension and Brakes
14
05-27-17 03:12 PM
sam430
38
05-19-09 04:56 AM
yoshi
17
06-07-05 11:41 PM
kam1996
17
11-10-03 07:10 PM
Quick Reply: Sway Bar Diameter Question
