SwiftSprings for 15 IS350 f-sport
For anyone who may be considering F Sport PTR07-53140 springs as opposed to the Swift 4T912 Sport springs as described in this thread, and want a noticeable drop, you may want to read my post (#68) in the link below.
https://www.clublexus.com/forums/is-...springs-5.html
My Swift's are on the way! Thanks ModInJapan!
After a ton of research on F Sport, Swift, RS-R Half Downs, etc; I have decided to use the Swifts on my wife's car, along with the SPC Adjustable Camber Arms. These arms are QUALITY.... made in the USA, and a bargain relatively speaking.
By my calculations the rear camber would be sub 2.0 negative and I despise irregular tire wear, so the camber arms should cure any of that.
I will keep everyone updated.
As information, the rear camber was 2.4*L/2.3*R negative after installation. Too much for my taste. Set it up to 1.4* negative with the adjustable camber arms.
Car drives perfect. I drive my F hard, my wife drives this car pretty aggressively at times too. As soon as I pulled it off the alignment rack I drove it on one of my favorite long sweepers.... 95 MPH and the car handled impeccably.
As the original OP Albert states, car rides incredibly. You would be hard pressed to differentiate between a stocker and one lowered with these Swift springs.
On the stock 18's the measurements to the center of the wheel wells with stock springs were 26.5"(F), 26.25" (R). After installation of the Swifts the measurements were 25.75 and 25.5, F/R respectively, for a net drop of .750-3/4". I am assuming they may settle a tad after a few hundred miles.
I'm leaning towards these springs now. a review has been posted about the f sport springs and the member stated that the drop was not noticeable (although they're reserving a true eval upon settling). but if the swift springs look like those pics above after install, that's a noticeable drop from jump and will probs lower another .5" or so. damn near perfect to me.
Again thank you for the update. I can't wait to slap mine on!!!
How much were the camber arms btw? Please post higher quality pics when you get a chance!
Josh, as you state, the drop is near perfect in person, the pictures do not do it justice. Car is filthy but I wanted to get a pic of it. Took some before/after pics but I am having trouble uploading multiple pics from my iPad, and that is all I have with me right now.
