Vibration from 40 to 60Mph
So I just changed both of my o2 sensor, and the car drives great but once I got on the highway I got a really bad vibration from around 40 to 60 mph . I mainly felt it in the rear of the car . Now here the part I don't understand , the vibration come and gose , after I run it for a while the vibration gose away . Now if this help my differential has gone bad so I hear that plus the vibration , feel like my drive shafe going come off.
So my question is the on and off vibration have to do with my differental being bad ?
Maybe the tran bushing / support bearing on drive shalf need to be changed ?
When changing the differental should I change the bushing too ?
Thanks for the help
Thanks for the help
Well I found out what my problem was , it wasn't my diff, it was my calipers , one in the front and one in the rear. Both were frozen. I found this out by doing two thing first I changed the line that goes from the calipers to the brake line once I did that the nose that I thought was the diff went away but I still had the 40-60 noise so we re looked at the breaks and saw that the calipers were frozen . Easiest way to find out if it froazn just drrive the crazy for 20 to 30 mins on the highway and then take it to a shop who was a heat gun , the heat gun tell you the temperature of your breaks if it over 200 then that where your problem is . Sorry if I miss spelled anyone I am at work
12jimmyjam
ES - 5th Gen (2007-2012)
23
01-03-20 07:24 PM
sonyman
27
09-29-07 09:46 PM
