3is RR-Racing USRS Bushings Review
I installed these (88duro version) on my 3IS non-F sport. On stock 17 wheels with Michelin PSS and a thicker rear sway bar. In combination it turns the IS into a superbly poised handler.
The bushing did not increase noise, and was totally silent in operation. In ride comfort it felt like going from 17 to 19 inch front tire/wheels; minimal additional harshness unless the road surface are badly broken.
The steering now feels alert, precise, progressively weighted, with excellent balance and improved feedback. Stability through corners is much improved, as in stability in braking.
The thicker rear sway nudges the car's cornering balance from understeer to neutral working well in concert with the improvements in the steering.
Definitely a worthwhile upgrade for anyone looking for a fast road car setup.
Last weekend I had the opportunity finally to take the car for a fast road trip with an extended section of curvy roads. The balance, neutrality and steering response with the RR racing USRS bushing and the stiffer rear bar was finally put to the test. I was super pleased with the result. The shift from stock, which is already good, handling, and the current set up is quite significant, and the front end bite is hugely improved. Having driven an F sport version (mine is non F sport) I would imagine the effect would be as satisfying and balanced.
I got the bar from Japan, and it was very reasonably priced. It's a stock RC350 part, not aftermarket or upgrade. Yes, the rear subframe needs to be dropped slightly to allow the bars to be removed and fitted. The RC rear bar has a almost unnoticeable effect on ride quality. The USRS bushing does increase the impact harshness of the bumps, but for a fast road car the trade off is acceptable. For upgraded handling, I would consider these two mods and a decent set of tires as the first things to do on an 3IS. The Lexus engineering really shows its potential with these upgrades.
Question about the USRS. I will be receiving my 2016 IS350 fsport in two weeks. I have a wife and two young ones in car seats in the back. Do you think the increase in stiffness/harshness will be too much for my wife and the kids? In addition, will it significantly benefit with stock suspension /ride height and stock sway bars?
Really intrigued with this product especially after seeing the video comparing the stock bushing and the USRS one on the ISF.
Thanks in advance.
Thanks in advance.
Former Sponsor
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Your wife sitting in the front passenger seat may notice it, but I wouldn't say it's a deal breaker.
Especially with the stock suspension, and perhaps even stock wheels, you'd feel it even less than me.
They also offer a softer bushing than their regular normal ones, and also a much stiffer bushing than their regular one. I have the regular bushing, which is in between.
In the back you probably wouldn't feel it as much since the bushings affect the front lower control arms.
Especially with the stock suspension, and perhaps even stock wheels, you'd feel it even less than me.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Great to hear that passengers in the back do not feel it as much. Will def get them. Just have to wait for the car to arrive now
Thanks to all for your feedback
Compthis
IS F (2008-2014)
13
08-03-15 11:36 PM
