Front Camber Arms
Just contacted Megan via email to confirm if it was true that 2IS RWD = 3IS RWD Front Upper Control Arms.
This was there response:
"The Front Upper Camber Control Arms for the IS350 RWD 06-13, will NOT fit the 2014+ Lexus IS250/350 vehicle. "
Are they lying?
Are they lying?
Not lying, but wrong Pm replied RSX.
My local Mechanic Came to the same conclusion VIA ALL DATA Part Numbers we identical 2g and 3g Upper control arms, now will the 2g camber kits should fit... anyone Tried?!??
I just put down a deposit to have a set of FUCAs made from Parts Shop Max. They've made three so far and are charging around $700 to have a set made. They said they'll put it into production but they don't know when exactly so for now they are doing one-off orders.
Looks like Megan Racing just came out with front camber arms for the 2014+ IS350 RWD only.
http://www.meganracing.com/product_d...=2438&catid=91
I got my rear camber from Good speed for my 06 GS430 and i have no more problem with back tires eating away and thats my rear lower arms i removed caused most lexus cars dont have adjustment at rear.l also found GOODSPEED was cheaper than MEGAN
Hey guys I just got my front upper control arms from Megan racing and have one of my technican from toyota installed it today and it does indeed fit. Seems like no one here had bought an upper control arm from them so I would like to be the 1st to tell you guys it does fit. Here is the part number : MRS-LX-0313
