Front and rear strut mounts. These look correct?
Hello all. Doing some suspension work and just wanted to verify that these look correct for our cars. They pulled up under my car 99 GS400.
Rear
http://www.rockauto.com/info/17/ST-5930__ra_p.jpg
Front
http://www.rockauto.com/info/904/903997__ra_p.jpg
Rear
Front
I have the same question--did you ever figure this out? It looks like the only component on the rear strut mount that you should have to replace is the "shock absorber cushion," a 6.00 part for OEM.
https://www.parts.com/index.cfm?fuse...-upper-CUSHION
Is it true that the rear strut mount is just that cushion, plus a washer (https://www.parts.com/index.cfm?fuse...itle%3D-WASHER), plus a nut?
I pulled my trunk liner out and looked at it, and it certainly looks like these are the right parts, and it doesn't seem like you'd have to replace the "support assembly" (which is 123.00).
Thanks in advance if anyone can confirm.
Clays93SC4
07-13-18 07:56 PM
Ariyanna
02-11-08 05:48 PM
