3IS 350 brake life?
Try out the Centric PosiQuiet pads. I posted about them in another thread. Very happy with them, and they are very affordable. https://www.clublexus.com/forums/sus...ml#post9213117
Former Sponsor
Are you sure you're looking at them in the correct pad shapes? They aren't the least expensive pad compound available but I wouldn't exactly consider them to be "expensive". In any case if you want the super low dust without sacrificing the performance there aren't too many options. If you don't play with the car so much or really mind decreasing the performance of the brakes there are several less expensive alternatives like centric posi-quiet (which we carry as well).
-Matt M.
-Matt M.
-Matt M.
-Matt M.
So basically, I don't need great pads. I need "good enough" pads to make it to lease end.
-Matt M.
-Matt M.
If the rotors are above min thickness, then you can resurface them and not yet to replace rotors. If there is a massive lip on it, then maybe replace the rotors. Even if it's an F-Sport IS. The front brakes all depends on how hard to drive really. 19k or more depends. I find it funny that you complain about prices, then don't lease/own a luxury vehicle.
4TehNguyen, don't appreciate your comment. I work as a Service Consultant Lexus Dealership under good management and we strive to do it the Lexus Way. That's how we became a top 10 dealership in the country. Don't knock everyone else because of one bad apple.
My beef is that at 8000 miles, my brakes should not have begun squealing and if they are wearing down prematurely, then I should not have to pay. But yet, if I do have to pay, then I am definitely not looking to buy the best/most expensive parts for a lease that needs to be returned in 8 months.
So...find it funny all you want. It isn't really as funny a joke as your assumptions/judgments turn you out to be. Having a luxury car doesn't mean you have to be a ****.
Lol. You can't tell anyone what not to do. We lease/own what we like. This isn't my first luxury vehicle. I've been through several. Some that cost way more. And none of them gave me brake issues so soon.
I think the brakes on a car like the IS350 should last longer than the 19K miIes that I had on them. It isn't an IS-F, or a Porsche or a GT-R.
Exactly! My breaks began squealing like pig at 8000 miles. I have almost 11k on the car now and I think they're going to need replacing before the winter.
The fsport pads are quite good as peformance pads. They have a strong initial bite, lineal feel, and good fade resistance on the track. The trade off is high dust and faster wear. If you only drive around town, the non-fsport pads will fit you better. During my 5k check up, I still had ~90% life left on my standard oem pads. Akebono pads have even less dust, but you give up some initial bite.
I replaced my front pads a couple weeks ago for the Centric PosiQuiet pads and I'm happy with them. They don't squeal, don't generate as much dust and the braking performance are more than acceptable although they don't bite as much as the originals.
I replaced them myself with a friend who is an experienced mechanic; it was my first time replacing brake pads and they where so easy to replace that next time I'll be doing the job on my own. I don't know about other models but on my 2014 IS 350 F-sport , the pads just slide in & out from the rear of the calipers. 45 minutes both sides done first time!
Note about dealership: According to them, my discs also need to be replaced because they are grooved but I took advice from my friend and I just replace the pads. After 28000 KM (17000 miles) the discs do look pretty good, but the original pads were completely worn.
DomLec - I put the PosiQuiet's on a couple of months ago myself, and had the exact same impression as you. I will tell you that now that they have been on a bit longer, I think even the initial bite is right up with what the stockers were now that they are fully broken in. I just couldn't be happier with having made the swap. And yes, most people don't understand just how simple changing brake pads really is. Honestly the "hardest" part is compressing the pistons back into the calipers to make room for the pads (since the old ones got thinner as they wore down). Congrats on the change!
