Why do people pair kyb's with drop springs if the kyb struts are oem replacements?
Old 12-19-15, 11:34 PM
bentleymp2
bentleymp2's Avatar
Default Why do people pair kyb's with drop springs if the kyb struts are oem replacements?
Just curious
The kyb gr2, now called excel-g (something like that), are oem replacements. Not designed for a lowered application.
Why then, do so many people pair them with drop springs?
Why would they be any better than the stock struts?
From my understanding, kyb makes the factory oem struts for Lexus. They might actually be the same.
That's all.
Thanks for reading!
Old 12-20-15, 08:48 AM
SweetS160
SweetS160's Avatar
kyb are actually valved 5% above oem struts. That is why most people can get away with using them on mild lowering springs. I've used them on Tanabe df210 and nf210. They lasted a lot longer with the nf210 due to the higher stance since both springs have similar spring rates.
Old 12-20-15, 11:16 AM
bentleymp2
bentleymp2's Avatar
Thanks for sharing your experience. That's good information.
I was considering them to pair with df210. How was the ride and how long did they last?
Will likely still go with bilstein B8 though because they are intended for this use. Any experience with bilstein?
Mocchan
02-11-15 06:57 AM
jmscott
06-26-14 11:11 AM
AYEmike
13
03-18-10 04:07 PM
das277
Suspension and Brakes
10-23-09 09:25 PM
Quick Reply: Why do people pair kyb's with drop springs if the kyb struts are oem replacements?
