Front upper ball joint popped out and clunking.
hi guys new here...
1.) i was reinstalling the stock suspension and noticed the front upper ball joint on the driver side has popped out. how did this happen? and importantly, how do i fix this?
2.) also there is a clunking on the front passenger side that only clunks at a certain point of rotation. triple checked all the bolts (shock, sway bar, and castle nut) and, loaded the suspension to torque to spec. what could cause the clunking?
tia!
i am not familiar with these ball joints, but quickly did a little research. is there supposed to be a snap-ring or c-clip of some sort on top also?
tia!
buy new upper a arms. they aren't that expensive. the balljoint is one unit in the a-arm. yours are shot.
clunking is the ball joint, its not even on the a arm anymore. it should be clunking when you are turning the steering wheel and hitting a bump at the same time.
well the clunking is on the opposite side of the popped out ball joint.
^Blown shock. Just replaced one of my BCR shocks that sounded very similar to that when hitting bumps, holes, un-even pavement just last month.
https://www.clublexus.com/forums/sus...hock-done.html
nismofreak
10-26-12 07:37 AM
ummagawd
Suspension and Brakes
04-12-05 02:20 PM
