AWD torque specs, front suspension
I am planning to swap out my LCA #2 bushings this weekend on my 2010 IS250 AWD. Can anyone provide the torque spec diagram?
I have seen this for the RWD but I was reasonably sure the specs where different between the two drive trains. If not, let me know.
Thanks in advance.
Thanks in advance.
olsen_karl (10-03-18)
Bkhectic (03-02-17)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/920x2000/31a03108_3989_4428_acf1_4149b3cdf8d8_da6f8540526ea734f9b741ef7fd32cfa5984a8ec.jpeg)
Hello all .. I am trying to find the name and part number for this specific part .. unfortunately I stripped the treads today while changed my struts on my
is250 awd .. if anybody can help it
would be greatly appreciated!
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/600x400/gen2_is_fr_lca_rr_dnt_600x400_a49f27e4f462c82967953a52aea193978e8d7458.jpg)
my bushings both end are flat .
I have bushings for front lower arm without the cone shape you thing I can install them like that or should I send it to a machinist to do the cone shape ??
thank you for the help .
I could be wrong, but they might work still. If you look at the RWD model LCA. They have a convex lip at the stud for 22mm nut. I can't remember if my AWD had this or not. I've tried to find a picture on ebay with out the bushing attached.
Search online to to see if you can see a convex end on the arm. If that makes sense in not look into returning them.
