wheel bearing
I started to hear a grind in my rear wheel and was wondering if I have to replace my rear wheel hub or can I just replace my bearing?? It is a 93 sc300
I am in the same boat as you, recently did my front LCA and noticed a binding in the hub when turned by hand. Yes you can change out the bearing but you will need at least a 10 ton press to remove the bearings and get the new ones in. I am checking to see if the dealer sells the complete hub assemble but I know it will be pricey. It will likely cost a good bit to get a shop to do it for you too.
I am thinking about getting a set from my local junk yard and getting a shop to press out the old one and install the new ones. All new bearing and parts per wheel is about $110.00 each, add labor to that and you can see that is gonna be expensive.
There is a write up here on this site on how to do it but you have to get access to a press.
I will post what route I take on this.
hahah that's funny just replaced my lca with supra one but yeah thanks so I can just replace the rear bearings instead of the whole assembly ? and how much are you thinking labor is going to cost ?
I am thinking about buying a Press from Harbor Freight Tools for about $100 and do all 4 hubs myself. All parts should be about $450 + the press should be about $600 for all 4. I will get some quotes form a couple of shops in my area to get and estimate and go from there.
I will do some more digging to find other options/solutions.
Rear:
Bearing Timken 511007 $65.79, National $54.79 on Rock Auto
Seals Inner $14.30 90311-63001, Outer $11.10 90311-57001 on toyotapartsdeal.com
or
Seals Inner $7.99, Outer $7.99 Toyota OEM on Driftmotion
Front:
Bearing Timken 510017 $34.99, National $36.89 SKF FW149 $50.76 on RockAuto
Seal $7.95 90311-50008 on toyotapartsdeal.com
or
Pretty good write up in maintenance section
https://www.clublexus.com/forums/per...placement.html
or
Front:
or
I cant find a write up for the rear hub but I think it would be almost the same as the front, though it will be more involved. You have to remove the axles and parking brake setup.
I checked 2 local shops in my area and got quotes from $50 to $125 to remove and press in the new bearings if I take the parts and hubs.
