Squeakty-squeak-squeakitin noises from my new to me GS300
Old 03-01-16, 07:19 AM
CrimsonGS
CrimsonGS's Avatar
Default Squeakty-squeak-squeakitin noises from my new to me GS300
Hey gang, new here. I tried searching but was not able to find information that would help me.
So I recently purchased a 98 GS300 - the previous owner lowered the car using I coil overs (no idea the brand - probably cheapies) and its riding on 18's. The car squeaks like in riding an ironing board down the road. I tried to spray lithium grease on some of the joints and bushings etc, but still squeaking like I kidnapped a tree full of squirrels :/
Any easy fix ideas on this one? I have limited access to tools and time, so any tips would be greatly appreciated.
Old 03-01-16, 07:43 AM
sakataj
sakataj's Avatar
Originally Posted by CrimsonGS
Hey gang, new here. I tried searching but was not able to find information that would help me..
Cause you didnt really try searching....
impossible to help you if you cant isolate a area or time it squeaks... where is it coming from, does it always do it when _____ happens
please dont make new threads,start here and actually read then try searching
https://www.clublexus.com/forums/gs-...iy-thread.html
rear could be the rear knuckle, rear axle carrier bushing, RUCA, shocks, subframe bushings and a few other things, front can be many more things so please help yourself and try and isolate it down to a certain area/place on the car
Old 03-01-16, 07:48 AM
CrimsonGS
CrimsonGS's Avatar
Thanks I appreciate the direction. Yeah I couldn't thoroughly search due to being at work. I'll follow your link. Thank you again
Old 03-01-16, 08:21 PM
firelizard
firelizard's Avatar
Replace all the ball joints and bushings that you know haven't been done recently. They're all gonna fail sooner (probably) or later. Ask me how I know.
Old 03-02-16, 10:23 AM
bruceb58
bruceb58's Avatar
front or rear?
Old 03-14-16, 10:29 AM
CrimsonGS
CrimsonGS's Avatar
Pretty sure its coming from the rear. I can stand outside and lightly push on the back end and it squeaks like crazy.
I just bought the car recently so I don't know what was changed out besides it being on Megan coilovers. Someone local said they had a fix which is push out the bushings and inject lithium grease in it.
Is that good or bad or will it even make a difference?
Thanks for the assist gents.
Old 03-14-16, 10:58 PM
bruceb58
bruceb58's Avatar
Lower knuckle bushing/bearing. I just replaced mine with the Figs replacement. Exact same noise that I HAD!!!
http://www.shopfigs.com/v1/index.php...product_id=129
I also bought the install tool that they mention in the instructions.
http://www.shopfigs.com/v1/index.php...product_id=201
You can buy others cheaper. I was impressed with the Figs part.
https://www.clublexus.com/forums/sus...ml#post9391861
Old 03-15-16, 09:42 AM
sakataj
sakataj's Avatar
you dont know that, your assuming.... the Megans were notorious for their lower mount bushing squaking very similar to the rear knuckle bushing. i posted a link to that ages ago and the fixed part (made by FIGs of course) just not gonna go search for it atm
Old 04-06-16, 09:07 AM
2k4CamkilA
2k4CamkilA's Avatar
I too have the same squeaking and creaking coming from both sides in the rear. It squeaks when the road is uneven.
Old 05-03-16, 06:12 AM
colinodon
colinodon's Avatar
Please check your tail light tightness... If they are loose they will squeal LOUDLY when pressed on. Just a thought to those out of ideas. They'll squeak when driving
Old 05-04-16, 12:54 PM
ThomasGS4
ThomasGS4's Avatar
Wait...what?
Old 05-05-16, 07:01 AM
colinodon
colinodon's Avatar
It's just an idea, if you're trying to locate a squeaky sound. I thought mine was my rear suspension but it turned out to be a loose taillight. It may or may not be your problem, I'm just sayin'
Old 05-05-16, 03:58 PM
bruceb58
bruceb58's Avatar
Apparently you missed this:
mickiegs
Automotive Care & Detailing
08-28-10 01:56 PM
GSLEXRUS
GS - 1st Gen (1993-1997)
12
07-11-05 12:20 PM
Tebabee
04-14-04 01:35 PM
kino1161OLD
02-12-02 06:03 PM
Quick Reply: Squeakty-squeak-squeakitin noises from my new to me GS300
