IS-F lower ball joint same as IS250 lower ball joint
Hi Lexus Peeps
Just inquiring if these parts are interchangeable, I would assume the IS-F ball joint would be stiffer and more sturdy than the IS250/350 ball joint since the IS-F carries more load and is a performance based car. what do you think and they carry the same part number
Manufacturer: Lexus
Part Number: 4333039625
Part: LOWER BALL JOINT
Part Notes: 2WD
Thanks
Albert
Manufacturer: Lexus
Part Notes: 2WD
Thanks
Albert
The suspension on the ISx50 and IS F is the same aside from shocks, springs, sway bars and the front lower No.2 control arm bushings. Everything else, including the subframes, control arms, knuckles, ball joints, etc., are the same.
There were some changes made over the years, usually coinciding with the same done on both the Sport Suspension option on the ISx50 and the IS F.
Jeff
Jeff
Did you by chance try to hammer on the side of the ball joint to release it? It often works without a press on other vehicles, or can you get a hammer in there?
I need to do front ball joints on my wife's RX330.
Former Sponsor
Don't use a hammer, use a large U-Shape ball-joint removal tool. You can rent it for free at AutoZone with a small refundable deposit.
Former Sponsor
Hi Lexus Peeps
However, a new ball joint will be stiffer than an old ball-joint.
