Creaking sound from front right strut ?
EV ftw!!!
I have a 99 GS400. I did the obligatory L-tuned shocks/springs upgrade (coupled with TRD racing sways, TRD front LCB and Toms Rear LCB) in early February. The car handles very well now and I had absolutely no problems at all. No creaking sounds from shocks settling or anything like that. Absolutely perfect!
Two days ago I just installed the TRD Front STB and Cusco Rear STB and yesterday I noticed a creaking sound coming from the front right strut when making left turns (right angle turns). I am attributing the sound to the strut tower because the creaks coincide with bumps in the road. Maybe my assumption is wrong, but that is what I think anyway.
Anybody else have this problem? What should I check? Bolts on the strut tower ..............?
Is this normal? I don't get the same noise from the left front when I make right hand turns.
Did you install the TRD STB yourself? Did you keep the black metal spacers on under the STB?
If the creak is repeatable on a certain corner for example, you could always take off the STB and see if it still does it.
EV ftw!!!
That's a good idea, regarding the stb removal. I will try that. Thanks!
EV ftw!!!
Hi Paul,
The creaking sound stopped all by itself the next day. I guess I don't have to do anything........
Hameed
Suspension and Brakes
04-27-03 10:55 PM
