How low can you go
Old 04-04-16, 05:47 PM
blizz24
blizz24's Avatar
Default How low can you go
Hello,
How low are you guys going without having a negative camber? I would like to drop the car but I want to have zero camber, or just the very bare minimum. Thanks
Old 04-04-16, 05:52 PM
Vivid101
Vivid101's Avatar
any drop will give you more negative camber.
Old 04-04-16, 06:07 PM
blizz24
blizz24's Avatar
I have seen alignment sheets staying within manufacturers spec after dropping the car. I just can seem to find the posts where I saw it.
Old 04-04-16, 06:37 PM
Vivid101
Vivid101's Avatar
I don't know. when you lower a car, it does not stay the same specs as stock height. I've never had a car that when lowered stayed the same factory alignment settings. That's my experience.
Old 04-05-16, 06:24 AM
Napalvr
Napalvr's Avatar
I have my AWD on RSR downs and the alignment is within factory specs all sit on th high side of the tolerances.
Old 04-05-16, 09:41 AM
blizz24
blizz24's Avatar
Anyone else agrees? I found a post (https://www.clublexus.com/forums/sus...ompatible.html) that 1" drop on all corners came out short on recommended specs. From what I have read here the RSR Down are more than 1" drop
Old 04-05-16, 10:23 AM
Sphinx007
Sphinx007's Avatar
even stock specs allow for some negative camber so I don't know how you can get 0 camber unless you get camber arms. If you get RSR downs and use camber arms to set it to 0, I think it may rub even on stock f-sport wheels...imo
Old 04-05-16, 12:26 PM
Napalvr
Napalvr's Avatar
Around 1.2 in front and .75-.8 in rear,but this is for AWD only RWD is more
Old 04-05-16, 04:38 PM
blizz24
blizz24's Avatar
sorry, I was referring to a big negative camber, I can live with stock spec or barely missing them
MIC123321
08-23-15 08:39 AM
doodoo
11-14-14 04:26 PM
edgeucated
Suspension and Brakes
12-02-12 09:38 PM
PhiDeltBee
IS F (2008-2014)
09-11-12 10:17 AM
1sWt2GS
06-20-11 10:16 AM
Quick Reply: How low can you go
