Looking for a rear toe link install DIY (FIGS, Megan, etc.)
Hey guys was looking to see if there was a rear toe arm install guide floating around.
I've been under my car a number of times and was hoping to see if theres an efficient approach to this.
Thanks
Thanks
Its pretty straightforward, remove the cam-bolts on the inside, remove the nut on the outside. REPLACE THE INSIDE NUT, these are one-time-use parts. Put the new part in just the opposite. Rotate the cam bolts so they are as far inside as you can get them. Adjust the length as best you can and drive directly to an alignment shop.
MizikeTSK
Suspension
02-16-14 08:04 AM
