IS200T suspension and rim question
any insight would be greatly appreciated.
these are the sizes I'm looking at :
front: 19x8.5 wrapped in 235/30/19
back: 19x9.5 wrapped in 265/30/19
will i have rubbing in the back? will they fit in the wheel well or will i have to pull the fenders a bit?
if so should i just go 235/30/19 squared?
if i go squared will i need to go with half downs to close any gap?
thank you for any help.
carid wont have the sizes in stock until the end of the month so I'm trying to get it squared away before hand.
or if you think i should go with a different size rim or tire let me know as well. thanks again
the offset range for this vehicle is between 33mm and 50mm. they are saying to use a lower offset going from 18's to 19's. but they don't know what offset I'm actually supposed to be using in that range.
just trying to lock down a good configuration i can use comfortably with this car.
mrshabo
Wheels, Tires & Brakes Forum
06-14-03 07:35 PM
