Bushings Question
Hi guys.
I have a IS350 2006 (100k miles and counting..) and recently replaced the LCA bushings.
In addition to LCA bushings, is there other bushings or parts that you recommend to replace for the suspension/steering of my car ???
thanks in advance!
thanks in advance!
Upper lower control arm, and you got the LCA, front and rear sway bar bushing, what's wrong with your car ? there is ton of things related to your steering and suspension.
Thanks! I have no issues but since the car is old I want to replace the bushings. Do you happen to know the oem part numbers of the bushings that you mentioned? Thanks again.
GS4TEK
05-07-12 08:44 PM
