rear sway bar end links
Re: rear sway bar end links
Originally posted by Din
what would happen if I drove around without the rear sway bar end links on?
Would it be possible to grind down where the two meet, or is the overlap too big? If its a slight rub, that might be able to be fixed on the link.
Good luck.
Re: Re: rear sway bar end links
Originally posted by Keith13b
You would just get some bad understeer, so as long as you don't go hammering though corners, you can live w/o the rear swaybar.
Good luck.
Good luck.
