Eibach/Tokico installed .... No more smooth ride
I put the same setup this weekend and it is a bit stiffer, but the noticable 1" drop is worth it. Question for you guys, did you need a camber kit for the alignment after the installation? Or can they align the car within spec with the new setup.
Did you get it aligned at a local tire store, or a proffesional shop. Cause i called Sears Auto store and they said they couldn't do it, so i called House of Mufflers and Brakes and they told me i needed a camber kit. Evidently these places not a clue on what to do. Did they align it original specs.
Thanks for the info. I found a profesional alignment shop and they aligned it to factory specs. It cost 60 dollars which is less then Sears does it for and said not posibble without a camber kit. Never again will i let a high school kid working part time at Sears work on my car again FYI....
Lucid
Suspension and Brakes
40
12-10-09 10:04 AM
blue99GS4
08-29-06 10:44 AM
Mrbig
05-29-05 08:14 AM
