(SC300 Springs) + (MKIV KYB AGX's) = ?
The fronts are the same, but the spring mounting plate on the Supra AGX is higher than the SC's. This would raise your rear end quite a bit. You really need the Supra rear springs to use the AGXs. And cutting the springs isn't a good option as you mess up the spring rate when you cut them
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
On my '93 SC300, I'm using Eibachs (for the SC300) w/Supra AGXs. Rear end height is unchanged (from using SC struts), but the spring seat is substantially smaller in diameter. I just cut the seat off my old struts, and it fits perfectly on top of the Supra seat. I tack-welded mine, but it's really not necessary (the pressure of the installed spring will hold it in place). Fronts are direct fit.
HTH,
TIM
HTH,
TIM
