C/D rear stock size rotors - Where to buy?
Hi guys,
I am trying to track down possibilities for stock size cross drilled rear rotors. I will be upgrading the fronts to StopTechs C/D and am looking to get a matching rear rotor. I like the slotted and C/D look but unfortunately StopTech does not have that option.
Thanks for any info.
When I ordered my kit, Mike asked me whether I want slotted and/or cross-drilled, black or gold. They may repaint them cap to black if you also buy the kit from you. It's not much work really. You can paint the cap black easily. Best luck.
Neo,
The OEM size rotor replacement is actually form Power-Slot. I was quite surprised when I opened the box and found out these "rebadged" rotors. Not sure what are the difference between Stoptech OEM and Power-Slot OEM.
BTW, sorry for the misleading for the color of the rotors. What was I thinking?! Like I said before, when I placed the order, Mike asked me whether I wanted silver or gold. So I assume that he can get either color... at least for the slotted application. I'm not 100% certain if this can apply to the cross-drilled rotors but I don't see why not. To be sure, I guess you would have to actually contact Stoptech.
Best luck.
Best luck.
Originally posted by Neo
I thought Steve's rotors were slotted/drilled, weren't they? I am looking for just C/D to match the fronts. Correct me if i am wrong.
too bad you didn't have drilled/slotted fronts cause just drilled rears wouldn't be so bad, but wouldn't work in your situation obviously. you know, just call steve anyways...he might have something for you
Originally posted by bravo261
you're right, i'm sorry. i didn't realize you don't want slotted...but you said and would be great?
futuregs
Wheels, Tires & Brakes Forum
06-13-03 01:01 AM
