Part Number Camber & Caster Bolt?
Old 03-21-17, 09:29 PM
KayGeeCee
KayGeeCee's Avatar
Default Part Number Camber & Caster Bolt?
Hey guys, just got an alignment on my car and was told that my camber adjust bolt was stripped so they could barely fix the alignment on my front right wheel.
Told I needed front, right camber and caster bolts on lower control arms as well as washers.
Wish I knew more so I can figure out what i'm looking at on the part diagrams.
I think the camber bolt part # is 48190-14040 but I'm unsure what the caster bolt is.
Any help would be appreciated thanks!EDIT: I think the caster bolt part # is 48198-50011. I just need to make sure
Old 03-22-17, 09:31 AM
RXRodger
RXRodger's Avatar
I am pretty sure a 48190-14040 will work for all 4 lower control arm bolts, but just to be sure call a dealer and have them confirm.
KayGeeCee (03-22-17)
Old 04-05-17, 09:36 PM
Luxor
Luxor's Avatar
The front camber adjust bolt is part number 48190-14040 and the rear is 48190-24020. When I say front and rear I am meaning the front part of the lower control arm and the rear part of the lower control arm.
Old 04-06-17, 08:59 PM
RXRodger
RXRodger's Avatar
Does anybody know what the update was on these bolts? It looks like originally there was an additional stud on the rear one with a brace or bracket that connected to that but later this was eliminated maybe? Hence, some of the info I found shows all 4 to be -14040. It is a little confusing in the parts lists I see.
Old 09-14-17, 12:47 PM
Returd
Returd's Avatar
My 92 doesn't have the stud for the brace, I saw a 95 in the yard that did have the stud for the brace, no idea on part numbers, but the one with the stud should work in both applications.
The350Girl
11-01-16 03:50 PM
scott101
Suspension and Brakes
09-15-14 07:56 PM
NinjaSocks
IS - 1st Gen (2001-2005)
05-15-12 04:42 PM
OneSickSC
11-11-10 05:20 PM
Quick Reply: Part Number Camber & Caster Bolt?
