RR-Racing USRS or FIGS LCA bushing
I freaken hate this forum especially 3IS.
like i said, "these" cars (meaning IS models) have dynamic toe problem. Not camber problem. If the camber was the problem then the rear tires would go out way before fronts do since it has more camber.
What you and the other dude is generalizing common camber problem. Again, not a lexus is
Here my car is on the Hunter Engineer Alignment Machine ! i might make a video that we Modify suspension on Porche Corvette Audi BMW, M series AMG RS7 R8 Nissan GTR ton of expensive and supercars at came to our shop for suspension. Don't get mad we're here to help you.
You just posted a bunch of pictures??? Good for you that you got a great alignment machine. And I'm not doubting your alignment skills.
Are you even reading what I'm posting? Please read what I've been posting.
Again, My car is completely stock and my alignment is within the factory specs. And it is not rubbing off anywhere. What I and other stock IS owners have is a toe issue. A camber wears the tire throughout gradually and a toe wears the tires just on the edge of it, which is what I and others have.
Again, this was already addressed in other Is model forum, including RCF, ISF, 2IS and RC, and the remedy is the harder LCA bushing.
Again, I'm not asking anyone about alignment or what type of wear I have. I'm asking about opinions and feedbacks of the LCA bushings.
We showed off pics because we wanna prove that we are not "Tommy Guesser"
LexNYC83 (04-03-19)
The illustration you provided shows toe wear is what caused the damaged on my tires.
Factory rears are set at around -1.5 and my rears are completely fine. Not even a camber wear. And yes, i ran anywhere between -2 to -3 in the fronts on my sti and i never had a wear like what i have on the IS.
Received 1,738 Likes
Just in case anyone is actually wondering what the real specs are for the front and rear camber, here it is:
Front camber
Rear Camber
For reference, alignment machines will show, on screen, the measurements indicated in the brackets () above.
Rear camber that is -1.5 degrees is pretty much spot on.
Front camber
Rear Camber
Thanks for posting the chart. Do you happened to have the entire alignment specs?
The camber and toe specified specs are so low on these factory spec'ed vehicle for it to have any premature wear. And after talking with FIGS Engineering and RR-Racing, they agreed that soft Lower Control Arm bushing is what causes the dynamic toe changes in which wears the inside of the tires.
For those who reading this thread, camber causes wear on the wider area of a tire where as toe causes wear on the small area on the edge of a tire. And Front suspension geometry on 2IS, ISF, and 3IS pretty much identical exception to the shocks and some minor components.
Front alignment specs:
Rear alignment specs:
Toe
Toe
jkonquer (04-25-17)
OG Member
The below video from FIGS Engineering clearly shows how the front tire toe settings drastically changes during braking conditions on OEM bushings and how toe becomes stable when using a high durometer LCA bushing:
jkonquer (04-26-17)
Thank you for the info. There are many misinformation especially on 3IS threads. Mainly due to lack of experience and general clientele of 3IS owners. But sometimes you just have put them on spot so no one is mislead.
sasnuke dude keep copying pics and info from other website.
redspencer if you said so, you meant Lexus selling lemon car ? which defected LCA bushing ? FIGS or any manufacture will prove something so they can sell their product, most members have this Issue because they lowered their car and changed their suspension geometry, how come Lexus IS 3rd gen STOCK in general don't have this issue ? and spencer dude jkonquer suspension isn't stock his car is lowered, Harder LCA bushing helps handling braking and turns, LCA causes wear unless it smashed or cracked. Honestly Spencer do you think OEM LCA bush caused Jkonquer's tires worn like that ? how come the rest of us stock don't have, at my Shop no Lexus has come for this kind of issue.
There's a video on RR Racings site with the owner explaining the benefits the USRS provides. I would suggest checking it out. Great stuff.
