RR-Racing USRS or FIGS LCA bushing
GSiGuy (12-17-17)
#95
After installation of the USRS or FIGs LCA, is it required to get an alignment? My assumption is no since the geometry of the front suspension has not changed, but looking for confirmation please.
#97
No, it is not necessary. But it is good idea to grt an alignment if you haven’t gotten it done in a while. My caster setting were within factory specs after i installed the USRS kit.
#99
I actually felt more NVH when I switched to Michelin PSS than the USRS kit.
#100
Any updates on the inner tire wear jkonquer? How many miles are you at now?
#101
Former Sponsor
I'de suggest putting the front on Jack stands with wheel chocks in back, or jack stands on all four corners.
#102
Sponsor
Sucks to hear that you had terrible experience. I personally never had any notable experience unless if I'm in a really bad roads. And I live in ****ty part of the suburbs and the roads are usually pretty bad.
I am really surprised to hear that anyone has issues with NVH with our USRS bushings. We have sold HUNDREDS of these and simply do not get complaints.
There are many reasons for squeaks and rattled in your car. Just because you install the USRS, and then hear increased NVH, DOES NOT MEAN that the USRS is the root cause.
I recall an incident where we installed USRS on an ISF and a customer complained to squeaks and rattles. I was really surprised. It turned out that another shop that installed his headers did not properly torque hissubframe bolts! So the added stiffness and added load transfer to the subframe due to the stiffer USRS bushings resulted in increased NVH and noise, but only because of of an improperly torqued subframe.
Failure to follow USRS installation and preload instructions could also cause NVH issues. But again, with all the hundreds of installs out there, NVH complaints are *EXTREMELY* rare.
Rafi
#104
Sponsor
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
