Alignment on lowered car
Finally winter is over so I had my new summer tires installed. The dealership noticed wear on the inners of the winter tires so I had a 4 wheel alignment performed. The Toe was adjusted but they couldn't adjust the Camber and & Caster because of my coilovers. They recommend me to go to alignment shop. I read that Toe is the most important and Camber can't be adjusted? Would just adjusting the Toe be enough? I don't want my summer tires to wear prematurely.
inner tire wear is common on our cars I believe due to soft lower control arm bushings that change the suspension geometry under braking. RR Racing offers their Ultimate Steering Response System or USRS to fix this issue and improve handling and steering feel.
In my situation right now, would an alignment for camber and caster be necessary? Is it true they can't be adjusted?
Adjusting caster is rarely necessary. Whether or not adjusting camber is necessary or not depends on what you are trying to do; what is your camber measurement now, and what do you want it to be? A degree or two of negative camber isn't going to make a real difference in tire wear, and will help the car corner better. If you are just trying to reduce inner tire wear, Aspect explained the problem and gave a solution. The other solution is to get lower control arm bushings from FIGS.
