LS400 brakes on 2GS help???
Old 07-09-17, 09:03 PM
PabloM85
PabloM85's Avatar
Default LS400 brakes on 2GS help???
Im currently in the process of upgrading my brakes im running on factory 16" wheels and was wondering which spacer ill need to run to clear the calipers. I've seen people say 5mm hub centric will clear then I hear it won't go with 15mm hub centric... pleae help lol I've gotten just about everything needed to do the swap. Thanks!
2 ls400 calipers pads and rotors
30mm rca's
still needing the correct spacer size to clear the factory 16" wheels?!?!
Old 07-10-17, 12:33 PM
sakataj
sakataj's Avatar
You CAN use 16"s Pete (PHML)proved it ages ago (2010) Post 371 from the link below or click the link in the comment i posted
https://www.clublexus.com/forums/newreply.php?do=newreply&p=8383299
Originally Posted by PHML
Those are 16 inch stock 2GS wheels.
I've run both the SAGE front 18mm kit and SAGE front 30mm kit on these 16 inch stock wheels.
To run the SAGE front 40mm kit, you will need at least 17 inch wheels (non-step lip).
Who told you otherwise?
Proof are in my pics. I have another thread that shows the SAGE 30mm front kit with these same 16 inch wheels...of course you need 15mm hubcentric spacer to push the wheels out.
https://www.clublexus.com/forums/sus...o-rubbing.html
Pete
OP can you just search instead of making a new thread next time. literally everything you wanna do has been covered. i simply searched under the keywords 16" ls BRAKES in the 2nd gen gs thread
BigBang
Suspension and Brakes
12
03-16-16 05:58 PM
Silver'04
03-13-14 10:00 AM
sc300Super
SC- 1st Gen (1992-2000)
41
06-12-11 11:35 AM
AusSC400
09-28-10 11:19 PM
romeo291
14
11-19-08 07:03 AM
Quick Reply: LS400 brakes on 2GS help???
