Rear Coilover Adjustment?
Hey guys/gals,
I was wondering if anyone else is having any issues with adjusting the rear BC coil-overs. i wanted to raise the car a little but I'm having trouble getting clearance for spanner/tool to properly turn, the trunk /bump stop on one side and then the strut on the other side, I was able to turn it a little but then the strut gets in the way and I can't reach all the way to the other side because the back of the trunk gets in the way.
There's also a ton of tension obviously on the spring, did you you guys remover the control arm bolt to release the tension or were you able to adjust without doing removing the bolt?
I know I should have take a picture but I didn't think of it until after.
I literally had to remove everything to adjust the springs... such a terrible design. I wish these coils were true type where the coils go over the shock.
Lexus went to the separate spring and shock to free up more usable space in the trunk.
clynnh1230
Suspension and Brakes
14
05-01-22 02:02 PM
Tempock
37
08-02-18 07:30 PM
