GS300 Brake Light Issues. when braking revers lights come on
Old 07-30-17, 02:41 PM
imadethat2
imadethat2's Avatar
Default GS300 Brake Light Issues. when braking revers lights come on
When I brake .. the reverse lights come on... what is the mystery?. is it the bulbs, switch or fuses?
Old 08-02-17, 11:12 AM
lexo98
lexo98's Avatar
[QUOTE=imadethat2;9940122]When I brake .. the reverse lights come on... what is the mystery?. is it the bulbs, switch or fuses
When you put it in reverse do the brake lights come on? Did someone put the bulbs in the wrong location on the back of the lamp housing?
imadethat2 (08-02-17)
Old 08-02-17, 02:12 PM
imadethat2
imadethat2's Avatar
Default Brake Light issues...
I have found out a little more of the problem... I do have the left outside bulb out... but the inside brake lights do work... and those are the ones that are appearing to look like reverse lights... I did a closer look .and it appears that the red film of the plastic cover has worn off from the inside?? and makes them appear to be reverse lights.. has anyone heard of this happening before... looks like I need to replace the inside brake lights cover... as well...? I confirmed this by backing up to a large glass window and check the brake pedal...and looking into the rear view mirror..
Old 08-03-17, 04:33 PM
MikeFig82
MikeFig82's Avatar
I have the the outers only from a 98 only. Pm if interested, or really upgrade to the DEPO LED Tail lights. You can find them on eBay.
imadethat2
Lighting
07-30-17 02:51 PM
Patr1ck
05-02-17 07:32 AM
2JZGTE-SC
SC- 1st Gen (1992-2000)
11-14-06 05:04 PM
Quick Reply: GS300 Brake Light Issues. when braking revers lights come on
