Suspension interchangable?
rodney978 (08-14-17)
Jumping in here. Could you elaborate on this, or point me to a thread that goes into this? I'm trying to understand how my AWD suspension set up is and in addition to that what exactly the selector switch does in changing the damping ratios for the AVS.
For AWD suspension, the front lower suspension mounting point is different because a Axle has to pass through it to be inserted into the hub to drive those two wheels. Where a RWD front suspension setup do not have to worry about a front axle.
The following 2 users liked this post by specONE:
Khatton (08-30-17),
MilkMonstr (09-04-17)
To add to this, thou the suspension components physically will fit on the rear, spring rates are different between RWD and AWD, and can affect ride height/comfort/handling.
Exhaust:
mid pipe is different, mufflers are the same, unsure on headers
Exhaust:
