EDFC Install Project: GS400
06-16-03, 03:44 AM
06-16-03, 03:53 AM
Northern California Regional Officer
EDFC Project
Without any suspense, here's the finished product:
06-16-03, 03:59 AM
EDFC Project
The Mirror control was relocated to an open spot that is just barely visible from the driver's position between the stering wheel and the turn signal stalk.
06-16-03, 04:04 AM
Step #1
The first step was to mock up the EDFC trim plate out of wood and fit it to the opening.
06-16-03, 04:06 AM
EDFC Project
The wood trim was then fitted to the EDFC. The original piece it replaces is shown below it.
06-16-03, 04:08 AM
EDFC Project
The finished piece is fitted to the dash. You can see the two aluminum mounting brackets I fabricated to bolt to the factory holes. You can also see the blue tape that I used to determine the position of where to re-locate the mirror control. That piece of tape was mounted ALL over the place before finalizing that location.
06-16-03, 04:15 AM
EDFC Project
The EDFC unit was secured to the back of the bezel using formed aluminum, then riveted and bolted into place.
06-16-03, 04:17 AM
EV ftw!!!
Wow, an amazing job you did there bro!! Let's see pics of the car too please. I want to see that drop!
06-16-03, 04:19 AM
EDFC Project: Mirror Control
The next step was to chop up the factory plastic piece and utilize the mirror control section as a base to create a new mounting bezel.
06-16-03, 04:24 AM
EDFC Project: Dash Template
A template of the dash countour was made of card stock. It was not symmetrical top to bottom as you can see. Next a wood form was created to copy the template.
06-16-03, 04:27 AM
EDFC Project: Plastic Forming
Flat Styrene plastic was then heated to form to the exact shape of the dash.
06-16-03, 04:30 AM
EDFC Project; Formed, cut & glued
The plastic was then cut and glued to what remained of the factory plastic housing. You can see the plastic matches the wood form precisely.
06-16-03, 04:32 AM
EDFC Project: Hand cutting & Shaping
You can see how the plastic was rough cut . The edges were then cut and rounded over at the edges by hand.
06-16-03, 04:34 AM
EDFC Project: Finished Piece
The finished piece was then textured and painted to match the factory leather look dash.
06-16-03, 04:36 AM
EDFC PROJECT : Completion - Ready for CARSON Meet
The dash was cut and the wiring harness relocated to it's new position.
